picture labview
   hi evryone,
Im a beginner with Labview   Do you know i can see a picture in my executable file.   In normal VI I see him  but when I debug it  it is lost. Ive tried to find some information about this problem but Ive found nothing. Can you help me smb. ?
thx tom
Message 1 of 10
(5,536 Views)
Please explain what you mean by "a picture in my executable file"? In particular what are you seeing in a "normal VI", and what aren't you seeing when you debug. Please describe this a little more,
Thank you,
Putnam
Certified LabVIEW Developer
LabVIEW Champion
Message 2 of 10
(5,529 Views)
I have normal VI with a code. Everything is OK but    I would like make classic application (exe). Unfortunately  When I build application a picture is not in fron panel in  exe file.  I know that problem is in path of file, but i dont know how i could solve it.
thx tomas
Message 3 of 10
(5,515 Views)
How are you generating the path? Are you adjusting for the fact that path's in an exe are different than in development mode?
Message 4 of 10
(5,504 Views)
first of all i would say thx for your endeavor. I tried the procedure  acording to http://digital.ni.com/public.nsf/allkb/FD7DE8BC8FFC256C862565F4006BE363 but it was without succes.   the wrong segment of my code is  In the  attachement. Could you tell me what i do wrong?    one again I would like say sorry for so stupid question.
thx tomas.
Message 5 of 10
(5,468 Views)
try somethign like this. Replace "YOURAPP" with whatever the name of your application is.
Message 6 of 10
(5,457 Views)
thx,
i did it,  but still when i run the application on another pc  there is not displayed a picture, but it shows a empty case.
Message 7 of 10
(5,435 Views)
Wire up the error out of the read jpeg function to an indicator. You need proper error handling to see what the problem is. You have a fixed path which is generally a bad idea but verify this other pc actually has an E: drive and that the jpg file resides there.
Message 8 of 10
(5,430 Views)
Accepted by pepistomas
Dennis is right, you should be using the "this VIs path" primative and modifying the path in relation to your VI to insure it works no matter where the application is run.
Message 9 of 10
(5,421 Views)
thx for help
best regard
tom
Message 10 of 10
(5,357 Views)
