picture matrix in picture ring
Does any body know, how to arrange the pictures in a picture ring as a matrix, as done in the ring of
http://digital.ni.com/public.nsf/allkb/279F064F0688C114862570900057678C?OpenDocument
This is very nice, but how is it done?
Herbert
(3,150 Views)
Its simple...
For consistency you should have all the images of same size...
Now drop a picture control on the FP and do the following operations
1) Click edit->Import picture to clipboard
2)Right click on the picture control and select the "Import picture from clipboard" from the pop up
3) repeat 1 and 2 for any number of such pictures (use the "import picture after" and "import picture before" for rearranging accordingly
Guru
Regards
Guru (CLA)
(3,145 Views)
Hi Guru,
I still don't see how it is done: I am talking about a picture ring, not a picture control.
Then, the control cited above has the pictures arranged as a matrix, whereas I only manage to have them in a row. This 2D-arrangement is new to me and I was not able to find out, how it is done.
Herbert
(3,117 Views)
Accepted by Herbert
Did you followed the procedure that was mentioned?.
Sorry to use the word Picture control. Read it as Picture ring and follow the same instruction.
I dont know how you managed to have it in row? And i think if the number of image exceeds it will get truncated to display a matrix sort of thing like the one attached here (I made this one after looking at your post)
Regards
Guru (CLA)
(3,111 Views)
Thank's!
I was impatient, wanted to have a 2 x 2 matrix and thus did not go beyond 4 images Smiley Mad.
(3,102 Views)
