pid to control transfer function
"i think my program is fairly ok. i need to plot a continous output and control the tranfer function with the P,I and D parameters. i have closed the loop. program still needs touches. can anyone help. also how do i enter a value of say 1/s^2+5 etc into the function. could anyone change my program to help please."
(2,787 Views)
I attempted to look at your VI, but you are using a library that I don't have access to.
The Library that's needed is GSIM....
I have some, but not all.. If you want a solution people will need the modules to be able to look at the problem
Hope this helps 🙂
(2,787 Views)
