pin 41 1-source 6025E
Anyone knows what is the output current of pin 41 1-source of the NI-6025E DAQ card?
Message 1 of 9
(3,584 Views)
Look in the spec that is referenced in the first answer at http://forums.ni.com/ni/board/message?board.id=170&message.id=180923#M180923.
Message 2 of 9
(3,578 Views)
hi there
i found this document :
http://digital.ni.com/manuals.nsf/websearch/91DE6638D38E621A862570CF006F23D1
see Page 2 for PFI 3/CTR1 SOURCE
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 3 of 9
(3,577 Views)
It says 3.5mA. I was under the impression that it was 13mA. Any comments?
Message 4 of 9
(3,568 Views)
Hi labview 1958,
Is there any paricular reason you are using a PFI line to source current?  Typically, you would want to configure a digital or analog output to serve this purpose, but maybe you can provide more detail on what you are trying to achieve overall.  Also, where did you see the 13 mA specification?  The 3.5 mA is correct if you are sourcing.  Let us know what you are tring to accomplish overall, and we might be able to provide better information for you.  Thanks!
Thaison V
Message 5 of 9
(3,545 Views)
I am using pin41-1_source to generate a TTL pulse which I feed into a TIP120. The output of TIP120 is connected to a dc motor. Thus by controlling the TTL pulse through a labVIEW program, I can contrl the speed of the dc motor.The duty cycle of the TTL signal can be changed throug a labVIEW program.I hope.
Message 6 of 9
(3,541 Views)
hi there
there are some examples shipped with LV on how to generate pulses with CTR with different duty cycles. go to "Hardware Input and Output/DAQmx/Genrating digital pulses" on the example finder.
Best regards
chris
Message 7 of 9
(3,537 Views)
Is CTR short for counter?
Message 8 of 9
(3,527 Views)
yep!
Best regards
chris
Message 9 of 9
(3,524 Views)
