playing multiple stereo channels out one single mono channel tia sal22
Greetings All
I have a vi which creates multiple stereo audio signals
in labview 8.6.1 and I would like to play all of the stereo channels out one single Mono channel
is this possible?  I tried setting all the device ID's to the same thing but a lot of clicks and pops occurred.  Basically I'm trying to play and mix all the signals out one mono channel at the same time.
Please note I would like to have each signal that is created played over
the mono channel at the same time.
tia sal22
(3,050 Views)
If all signals have the same sample frequency (dt), you can just add them together then output them as mono. They must of course also have the same number of samples. But that can fixed by inserting zeros in the arrays.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,041 Views)
Thanks but which options allows me to do this
tia sal22
(3,032 Views)
Accepted by sal22
tia sal22
Just add the arrays if they have the same length. Use the standard add function (like in 2+2=4). Then arrays are added each index is added together
(3,014 Views)
