please HELP for a simple formulation
I am currently running a project for a heat exchange process with a simple formula Q=m*DH but variable m (mass flow rate).
I am new in LabVIEW and I am trying to create a graph of Q related to time. I have attached a file with my VI while also the time and the variable m. I am struggling to put 'm' as a variable and then plot Q against the defined time (45.5 hours).
Can anyone help me with this kind of problem?  I have already made this calculation in a spreadsheet file which was easy but i would like to present it in LabVIEW.
Thanks for your help.
Message 1 of 11
(4,495 Views)
Hey Chris,
Looks unclear to me where is your "m", "time" or "Q". I can see the calculation but it only operates on one value. Can you please be more specific on what is what and what is your goal ? Maybe add some comments in your VI 🙂
Thanks.
CLAMaxime -- Kudos are a great way to say thank you
Message 2 of 11
(4,488 Views)
Hello ML927,
Thanks for your reply.
I am struggling to create a variable 'm' with respect to time rather than having a simple controller that operates only once. So in equation Q=m*(H1-H2) I would like:
m= variable
H1,H2= constant
So my goal is to plot Q in respect to time as attached in the png file. Q is the output.
Please see the attached files. I made some comments to the VI file as well.
Thanks a lot,
Chris
Message 3 of 11
(4,472 Views)
Accepted by Chris12341234
Copy that. Would something like that work for you ?
Steps :
  1. Convert your strings to numeric arrays (need to index the 2D array created)
  2. Use a For Loop to run through all the values of "m"
  3. Do the calculation you want inside the loop.
  4. Index the output of the loop so taht you get all the calculated values in a new array
  5. Bundle the time (x) et Q (y) arrays to display on a XY Graph
Do all those steps sound familiar or do you need me to go into more details ?
Message 4 of 11
(4,465 Views)
Thanks very much this was helpful.
I have completed your guidance but I cannot get the data in a chart form. Check the attached file.
Message 5 of 11
(4,431 Views)
You forgot to index the Q1 output on the loop. Right-click the orange output tunnel and select Enable Indexing.
As for the chart, there is a specific indicator on the front panel called XY Graph. Just drop it there and wire the bundle function to it.
By the way, on the Index Array VI you wired the line index and not the column one. So you don't get all the values...
Message 6 of 11
(4,426 Views)
Your guidance helped me a lot. I really appreciate that. It worked everything is fine!!! I have attached the file so you can have a look.
I have 2 more questions.
Is there any way to make the graph with smoother lines (like in the png file in the previous comments)?
Also, is it possible to use a time delay while the graph appears? I would like to run it like a simulation.
For example, do the loop every 1 second and present the result both in the graph and output cluster every 1 second and not rapidly. This is just to enhance the user's interface. Smiley Very Happy
Message 7 of 11
(4,407 Views)
Hey Chris,
Happy that it helps. Just a quick example of what you can do :
If you are not comfortable with what I did, please tell me.
Message 8 of 11
(4,384 Views)
Can these calculated values appear in an indicator while the simulation is running?
For example, run the simulation and appear instantly each result as attached in the picture.
Message 9 of 11
(4,330 Views)
If you use the property node to reference your arrays, you can change the index value to the value you need :
More info on property nodes :
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/property-node.html
https://blog.digilentinc.com/using-property-nodes-in-labview/
From the discussion so far, I think you need to get used to four things which will help you in the future : manipulating arrays, loops, references and property/invoke nodes 🙂
Message 10 of 11
(4,326 Views)
