please help for a simple question to modify string content . Thanks for help !
Hi:
 I try modify this attached file.
I want change name from TC000649 to testcase2.
but after I save as name testcase2. it keep as name TC000649.
it did not change to name from TC000649 to  testcase2.
I try file, save as
 copy -create a copy on disk
substitute the copy for original
create a unopened disk copy
open additional copy
rename file.
they all return No change.
please help me.
(3,773 Views)
Accepted by zy6
Did you try ...
Edit >>> Make current values default
Ben
(3,765 Views)
Accepted by zy6
Are you talking about the contents of the string called "name" in the cluster called "TestCase"? "TC000649" is currently the default value. To set a new default value, right-click the string control, select "Data Operations", then "Make Current Value Default".
(3,763 Views)
(3,742 Views)
(3,667 Views)
