plot wavelet denoise
When I plot the output of wavelet denoise.vi it doesn't look anything like the original signal:
Here are the settings:
Why doesn't the nes signal look similar to the original one?
Thanks!
(3,987 Views)
I am getting Fine output have a Look on the attached VI.
Message Edited by Baji on 06-10-2009 10:21 AM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,977 Views)
How you are feeding input to the denoise VI?
Balaji PK (CLA)
(3,974 Views)
Accepted by Richard_Z.
I figured this out - it is the wavelet setting that changes the shape.
(3,956 Views)
