plot with non linear x-axis value in chart
some mistake in my previous message in the undelined line.i wrote as i could .please read this and reply me.sorry
Hai i attached the same program in 8.2 version.I clearly explain you wat i need.im goind to measure the width of material when ever measure button is clicked.In the meanwhile i have to plot the run chart for this measurement.I hope u know wat is run chart.my requirement is the x and y axis of the of the chart is time and width correspondingly.The condition is the x-axis time will be the time at which the data acquired.for example if  the data is acquired at 11am,1pm,7pm.the first value in the xaxis will be 11,the second 1,the third one 7 pm..
It should not be 11,12,1,2,3,4,5,7.Please help me to solve.The another problem is in xy chart i able to plot the data with respect to time provided the value  in thex-axis as 11,12,1,2,...5,7.i cant achieve as 11,1,7 in xy chart also.But here in run chart i could not do that also.reply me friends
In the attached program i name a chart as expected run chart that is wat i want to be .In that expected run chart i manually write the xaxis time to show u how i want it be.u go through u will understant.u run that and try to help me
kavi
kavi
Message 11 of 13
(1,106 Views)
anyboby helpme to solve this
kavi
kavi
Message 12 of 13
(1,105 Views)
Hello Karpaga,
you need to go to the properties in the chart on the front panel, go to DISPLAY FORMAT, Select X-Axis, then in the Type field, select Absolute time. you will get the absolute time on the X axis. I have attached an image of the window.
Vishal
Message 13 of 13
(1,078 Views)
