plotimages
Hi!
Im using plotimages from the property node of XY Graph to plot objects in the background of the graph. I encounter 2 problems:
1:It is working fine when I use an cluster as input, but when I compose a cluster by bundling 4 inegers, nothing appears on the screen, Why?
See the attached VI, image as example.
2: Is it possible to implement more than 3 (front, middle, back)object in the background of the graph? I would like to plot 4..
(3,526 Views)
Accepted by topic author PabloNL
Problem 2 solved, I can use the output of one draw oval.vi as input of the next draw oval.vi to implement more objects.
Still wondering about problem 1.
(3,511 Views)
Hello Pablo,
The problem is not in the cluster itself, it's in the data you're providing to it.
In your problem part you have:
Left: 54
Top: 553
Right: 80
Bottom: 527
This is "physically"  not possible.
The "Left" value should always be smaller than the "Right" value: This is ok.
The "Bottom" value should be bigger than the "Top" Value: This is not ok here.
Please keep in mind that the (0,0) point is in the top-left corner of the Graph and from there on your values will increase.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,463 Views)
