polynomial roots accuracy
Hello everyone,
Does someone know the accuracy of the polynomial root function
up to how many decimal can i be sure of root result   ?
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(2,871 Views)
Accepted by topic author tinnitus
Hello Tinnitus,
Sorry for this late answer but we had to discuss this issue internaly and make some tests. You can use either 'general' or 'advanced refinement' option to define your polynomial root accuracy. However there is no detailed documentation about this.
In our experience, 'general' option is fast, normally with 6-10 digits accuracy, depending on polynomial order and type (like repeated roots).  But one disadvantage is 'general' option can not ensure the roots are exactly real or complex conjugated.
'advanced refinement' can ensure the roots are either real or complex conjugated, normally with higher digits accuracy than 'general' option.  It can deal with repeated roots situation.   But it is slower than 'general' option.
For other two options, you should have some knowledge about the polynomial.
I hope that helps.
Best Regards,
Yannick.
(2,779 Views)
