pop-up using event structure
Hi
Is it possible to use an event structure to call several subVI's?
Look at my program i've attached.
Its now not possible to open another subVI when i've already loaded one. I have to close the subVI and THEN call another subVI.
Is there a way where I can open all subVI and not just one at the time?? ..so i can operate on all subVI's (and mainVI)
thanks
Bjornar
(3,258 Views)
Hi Bjornar,
i think it is possible, but i can´t say exactly because you forgot to attach your example.
Mike
(3,255 Views)
ooops Smiley Tongue
here it is
Message Edited by MrNorway on 01-31-2008 11:10 AM
(3,250 Views)
Well, it's all in the dataflow. The current event cannot complete until everything in it has completed. You have several possibilities:
Place each into a seperate loop and event structure (see attached. Make sure not to lock the FP for the events).
Launch the subVIs via a reference and the run method, for example.
(3,218 Views)
thanks altenbach! Smiley Very Happy
(3,216 Views)
