pop up vi screen size
Hi all. I am using horizontal splitter in main vi. My menu buttons are in upper pane and my lower pane is empty. I can call my sub.vis front panel in my main vi. But I want  set all sub.vis front panel size same with my lower pane.
Is this possibe?
Thanks.
(2,529 Views)
Sounds like you should be using a Subpanel.  With that, you just load which VIs you want displayed in the subpanel and it will be the size that you make it.
(2,519 Views)
