potential bug report (LV 2011): new input/output not updated in help window
A little bit later, kind of the opposite situation:
Message 31 of 53
(1,534 Views)
Does it make a difference if the context help window is open or closed while you edit the connector pane? A quick test on my installation seemed to show that the help isn't updating if it's not open.
jattas
Message 32 of 53
(1,515 Views)
My Help Window is pretty much always open, so no, it doesn't make any difference. Note that if you read the whole thread, it is more than just a lack of Help Window update. There is another annoying bug that prevents from relinking to the edited VI. This is a serious issue (I mean, there are simple workarounds, but this is still an annoyance).
Message 33 of 53
(1,508 Views)
I am getting the same behavior.  I had another post.
http://forums.ni.com/t5/LabVIEW/linking-control-to-terminals-on-connector-pane/m-p/1708348/highlight...
Kudos and Accepted as Solution are welcome!
Message 34 of 53
(1,494 Views)
Just noticing something: when we click on a connector AND THE HELP WINDOW FUNCTIONS AS EXPECTED, is the selected input (or output) highlighted in the help window? I can't remember (and I can't check since my help window is dead)...
Message 35 of 53
(1,457 Views)
In LabVIEW 8.6, the connector will flash in the help window when you have the wire tool over the corresponding connector.  Note, only the rectangle/square for the connector pad blinks, not any of the words.  This only occurs when the VI is called as a subVI.  If you are working in the VI, and hold the wire tool over the connector pane, the help window will not highlight the connector.
I see the same bahavior in LabVIEW 2011.
Message 36 of 53
(1,454 Views)
It just dawned on me that it would be useful to have the whole thing blink or something...
Message 37 of 53
(1,451 Views)
What do you think about this one:
It is LV 2011, but where did the icon go? Smiley Very Happy
Actually, as a matter of fact, it appears that this is not the only VI to experience this interesting mutation:
Smiley Very HappySmiley Very Happy
Message 38 of 53
(1,434 Views)
I have the same problem.
Sometimes a new VI will NOT show the new connections I've made in the connector pane.
Saving the VI, running it, or including it as a subVI in another VI won't help.
Changing the layout of the connector-pane usually helps.
Very annoying nasty little bug!
Jens
(running LV 2011f2 32bit on Win64bit)
Kudos are welcome...
Message 39 of 53
(1,417 Views)
Has NI acknowledged this as a bug yet?
Message 40 of 53
(1,392 Views)
