potential bug report (LV 2011): new input/output not updated in help window
I have also suffered from this problem, but I found that by changing the selected connector pane pattern, then returning to my original pattern, the problem seems to go away.
Message 51 of 53
(679 Views)
I'll try this workaround and see whether I have better luck than with Warren's. However, that's already 3 workaround suggestions. If that's all we achieve, that's not so bad... (after what, 4 months?) 🙂
Message 52 of 53
(674 Views)
Well, I tried danren934's suggestion, but it did not work for me. 😞
However, my trick (change the connected object whose terminal does not show up inthe connector pane from indicator to control -or reciprocally- and back) works reproducibly...for me!
Message 53 of 53
(648 Views)
