12-28-2005 02:52 PM
12-28-2005 05:44 PM
12-28-2005 05:47 PM
Actually I'm not sure that the dial behaves any differently than the slider.
For both, the pointer follows the cursor whenever the left mouse button is held down. The only difference being that with the dial, once the cursor crosses the dividing line between the max and min values then the pointer quickly flips over to the side that the cursor is on. With the slider your cursor just can't travel up far enough to wrap around to where you suddenly find that you are below it.
I don't think you are going to be able to do anything about this - I think it's a feature.
12-29-2005 09:33 AM - edited 12-29-2005 09:33 AM
Message Edited by Chaos on 12-29-2005 09:35 AM
12-29-2005 01:06 PM
12-29-2005 01:18 PM
Hello Chaos,
Can you put your llb in LabView 7.1?
Thanks ion advance
12-29-2005 01:30 PM
As Chaos explicitly mentioned, you need 8.0 because an Xcontrol was used, and that's a new feature.
One way you might be able to do this in 7 is placing a transparent control above your control, registering the mouse down event for that control and transferring the values from that control to your own. You can then use whatever logic you like to make sure that it only goes up and not down.
12-29-2005 01:41 PM
12-29-2005 01:49 PM
12-29-2005 02:10 PM
