print blockdiagram results a blank page
Hi there,
as for documentation I have to print out the block diagram of my project. I've used the print function in LabVIEW but there is nothing on the page, though in preview I can see that clearly. But I can print the hierarchy anyway.
The block diagram should be printed on an A0 paper.
Has anybody the idea, what can I do instead?
Wilbur
(2,444 Views)
Wilbur,
what LabVIEW version are you using? In general the issue is probably caused by an issue of the printer driver. Is it possible to print on another printer or to print into a PDF file?
Just a general note: In LabVIEW block diagrams should never have a size, that they need to be printed on an A0 paper. Huge block diagrams can always be avoided by choosing an appropriate design pattern and hierarchical programming.
Kind regards,
Jochen Klier
(2,420 Views)
