print dialog window in report generation
Hi...
I would like to create a report from my database and send it to printer. Basicly i want to use something like print report.vi in labview examples. But the sample is print directly to the default printer, how can i display print dialog window so i can select the printer and set another properties.
Thank you
(2,262 Views)
After some searching, I found this thread:
http://forums.ni.com/t5/LabVIEW/Printer-selection/td-p/23136
Some VIs were posted which look like they should do what you need.
(2,229 Views)
