print screen front panel to specific path
Hello All,
I would like to do print screen from VI front Panel to specific location. I am trying to use "Append Front Panel Image to Report VI" but i Can't add specific path there.
Co question is how to do print screen from VI front Panel to location generated programictycallly ?
Best Regards
(3,987 Views)
Attach your code, and someone will point out how to fix it.  When you do the attachment (and, please, attach a VI or a LabVIEW Snippet, not a screen shot), also indicate the Path you'd like to use.
(3,974 Views)
Accepted by topic author plpablo
Hi pablo,
two steps:
- use a method of the VI to read its frontpanel image
- use one of the PictureFile functions to save that image to a file with a path specified by you. (I recommend to use PNG.)
Done.
(3,949 Views)
Hi GerdW,
Thank you for answer I see Your labView is in German. Can you tell me name of property in English
Print screen in attachment
(3,941 Views)
Hi pablo,
I said you need to use a method and I wrote the translation of the German name in the image…
(3,939 Views)
Here you can find it:
It is important that the Method Node has focus to the selected class "VI". You can force it by wiring a reference constant of "This VI" to the node or select it manually with context menu entry "Select Class" (reference input of method node must be unwired!)
Greets, Dave
(3,933 Views)
