printing from a file
Is it possible to print a string of numbers from a file after the file is called? i have tried printing a graph on the screen by setting the VI to print panel when VI completes execution, and it prints whatever is displayed on my screen.
My aim now is to run a for loop of 10 random numbers and printing those 10 numbers after the loop ends execution. Will it be necessary to use Excel for this function?
Hope someone has some comments on this 🙂
(3,334 Views)
If you want to print a graph, you should make a subVI only containing it, and with the format you want for the printing, and set "Print panel when finished". When you want to print your graph, pass data to the subVI, and it will print it. If what you want is to print data, you could make the same but using other format but a graph in the subVI, for example, an string control. There's the option to write directly to the parallel port using serial port vi's, and use ESC-codes to format data (most printers accept them), but that can be relatively much work.
Hope this comment helps :)"
(3,334 Views)
You can use the report functions. LabVIEW 6 also supports including a graph in the report. There are report examples included with LabVIEW (Examples>Advanced>Report Generation).
(3,334 Views)
Dennis,
my main problem is that im using LabVIEW 5.0 and most functions are not available to me. if you can help me with the 'printing function', do feel free to drop me a line at hyukie_35@hotmail.com
thankyou
(3,334 Views)
I think your only alternatives is to pass the strings to a sub-vi that is set to print when finished as Gorka mentioned in his reply or to use Excel or Word.
(3,334 Views)
