printing the front panel with arrays
I have a cluster with 15 graphs in it. When I open the front panel in labview 7.1 and print it, All the graphs are printed on the sheet. But when I open in 8.5 and print the front panel only the graphs that are visible on the screen are printed on the sheet and rest of the cluster is blank. Can any one tell me why is this happening and how can I print all the graphs when I open the application with labview 8.5.
Mudda.
(3,096 Views)
Hey,
You have different options in 8.5 wherase one is "printe complete frontpanel" and another one "print visible portion of frontpanel".
Which one did you select?
Christian
(3,068 Views)
Hello Christian,
what options are you talking about? Are you talking options while I print the screen or in the Tools>Options tab?
(3,060 Views)
Hey,
I'm talking about the dialog which appears when your press File>Print in the menu. What way are you using to print the FP?
Christian
(3,053 Views)
I've rencently run into a similar problem, and I think 8.5 is buggy in this respect. How are your data structures? In my case I had a 2D array where each element was a cluster containing a graph. Similar to your observations, areas outside the window boundary did not print out correctly in 8.5. Things worked better when I use 8.6.
I have not fully investigated this, so I have not filed a bug report yet.
(3,047 Views)
Hey,
I was able to reprodcue it in 8.5 now, however it works with 8.6
Christian
(3,029 Views)
