probe window values on a restart
hello,
The probe(s) will hold there value when you stop and restart a simulation but it can be confusing if your code is working properly if the value are retained from the last simulation. Can the Probe values be reset somehow between each simulation??
thanks
(2,340 Views)
Verify your Retain Probe Values is enabled in your simulation vi
AB
Kudos are Accepted
(2,318 Views)
This has nothing to do with the question asked.
(2,314 Views)
No.
(2,313 Views)
