problem about datasocket and activex
when I embeded an datasocket activex contorl(made with VB6,labview UI
included,pacakged to .cab file) in a web page, it can not be appeared
in client computers. I have adjusted the security in IE,but
fruitlessly. If the activeX contorl didn't include the activex
controls NI provided, it can be appeared in clients.
what should I do?
(2,587 Views)
Hello plainman,
Thank you for contacting National Instruments.
It appears that you are having problems displaying embedded ActiveX controls in a web page on a remote client.
ActiveX controls embedded within an application do not display on a remote client because they are dynamically linked to files that reside on the local machine. You may be able to work around this problem by adding all of the applicable .ocx files to each client machine.
I hope this helps! Let me know if you have further questions.
Matthew C
(2,587 Views)
