This widget could not be displayed.
run parts of a vi front panel in different windows
I have a devicenet main vi. I want to call up sub VI's and transfer boolean arrays into the main vi. I want the main VI and the sub VI to run in separate windows. I can't get the array data out of the sub into the main. I have the indicator of the array in the sub tied to a icon terminal. The icon terminal goes into the main vi loop and connects to the d-net input. Please help!!!
(2,505 Views)
Make sure your data in the sub VI is not inside the loop. If your data is inside the loop, the data will only transfer to main VI only after it has finished executed. Can you post your VI? so that someone here can help.
When you feel sad, laugh
(2,505 Views)
