problem for to select automatically the cell in the control tree .
hi.
how to select automatically  the cell in the control tree ? or to flash the cell that I returned in command like you see.Untitled.png
thank you.
(3,085 Views)
Accepted by Sarah_LAB
As billko said in your previous thread it is not easy navigating a tree control. To programmatically select a row you need to set the active row, get the active cell string and set the tree control value to this cell string.
Ben64
(3,049 Views)
Thank you for your help, but it does not work... 😞
(3,031 Views)
t's okay i solved the problem but how can i move automatically  to the vertical scrollbar???
(3,028 Views)
