problem in displaying x axis data in waveform graph
Hi pskpsk,
Do you find the way to solve the problem you stated? I am having same kind of issue that you were having. If you solved it, could you please help me in getting thorugh it? Thank you.
Message 11 of 12
(732 Views)
pskpsk has not logged in since 2012.
Please start a new thread. In it state clearly what you want to do, what you have tried, and what the problem your are having is. Be as specific as possible. Run your VI until it shows typical data. Stop. Edit >> Make Current Values Default. Save (under new name). then post that VI so we can see what you are doing with your data.
Lynn
Message 12 of 12
(722 Views)
