problem of subpanel with event structure in the main vi
I am using Labview8.2
I need to call a subvi with an event structure there. It works well when there is no event structure in the main vi. When I place a multilistbox control, and I want to lead the row of multilistbox into subvi. So I add an event structure and register a "double click" event. But there is a problem after I do that. I post a example in the attachment. Is there anybody know how to fix it?
(2,932 Views)
This seems to work for me: just put the call to subvi outside of the event node.
side note: maybe you want to put the event structure inside a while loop, so every time you double click on the table the command will be executed.
attached.
Message Edited by Gabi1 on 10-16-2007 12:11 PM
... And here's where I keep assorted lengths of wires...
(2,925 Views)
sorry my mistake.
you need some modification of the subvi, together with the main.
for looping we need a little bit more elaborate solution.
(2,916 Views)
I also have solved it. It's the problem of "lock front panel bla bla..." checkbox in the event structure. If I cancel the selection of the checkbox in the mainvi, then it works well.
thank you anyway. your solution works well too.
(2,895 Views)
