problem plotting binary file
hi, im recording data on a pda using cf-6004 and the attached analogue input vi - the data attached has 700 samples acquired at 10,000Hz, the objected being monitored is vibrating just below 5kHz - this bit seems to work fine
problem - when i come to read the data, fft it and plot it it seems to treat each sample as 1 second and so gives a wrong fft freq value, how do i get around this?
thanks!
andy
(2,699 Views)
When you save the data, you are not saving any timing information. You just have the raw data. In your acquisition, you are just assuming a default sample rate which is maybe not such a good idea either. If you want to stick with assumptions, then when you read the data from the file, create a waveform data type and specify a dt of 1/sample rate before wiring it to the Spectral Measurements function.
For better code, you might want to look at the shipping examples where logged binary data has a header created that includes the sample rate.
(2,695 Views)
