problem to remove dc offset from different signals
Hi !
I work for a signal processing subject. I acquire three different signals from three accelerometers ( Position x,y and z). The sampling frequency that I chose is 25 Khz.
My problem is at the subtraction of the offset from the signals . the following error appears : "Error occured at subtract -1802 in READ-TDMS.vi
I really need help! Here is what i have done
Thanks!
Message 1 of 10
(7,913 Views)
Accepted by mehdi33
Is this what you ment?
Message 2 of 10
(7,898 Views)
Accepted by mehdi33
Wouldn't it just be simpler to have AC coupling on each accelerometer?
Bill
CLD
(Mid-Level minion.)
Message 3 of 10
(7,879 Views)
Hi AdamTrojak !
Yes that's what I wanted. Thanks for your help!
Message 4 of 10
(7,837 Views)
 Hi
Yes you are right. I did not know at the beginning of my tests that AC coupling eliminates the offset of the signal.
Thanks for the information!
Message 5 of 10
(7,833 Views)
Hello!
I'm glad that I could help.
If you find my post as solution - mark it as solution 😉
Message 6 of 10
(7,817 Views)
@mehdi33 wrote:
 Hi
Hi, mehdi33:
An additional reason why I suggested AC coupling was, as a general rule, you should clean up your signal as much as possible with hardware before subjecting it to measurment instruments.  Let's take a situation applicable to your situation, but using numbers convenient for discussion.
Let's say you have a setup where your accelerometer amplifier accepts a peak signal of 5 Volts.  Your accelerometer puts out a signal that has a peak voltage of 3 Volts.  We're okay right now.  But what if the DC offset is +2.5 Volts?  Now you have a 3 Volt signal plus a 2.5 Volt DC offset = 5.5 Volts!  Assuming the manufacturer was exact and not conservative with the amplifier spec, you're probably going to get some clipping!  Maybe a worst case scenario is that you blow something up!  No amount of software compensation will allow you to recover the original waveform - or damaged equipment - (although there are some algorithms that can do a reasonable guesstimate of what the signal used to look like).
Just my two cents worth of input.  😄
Bill
CLD
(Mid-Level minion.)
Message 7 of 10
(7,754 Views)
One caution: If you are using gravity to do some initialization or "calibration" of the accelerometer, then you will need DC coupling.
Lynn
Message 8 of 10
(7,739 Views)
Lynn
Oh, I actually did not know that!
Bill
CLD
(Mid-Level minion.)
Message 9 of 10
(7,722 Views)
Hello!
Thank you very much for your advice. it helped me to better differentiate between the AC coupling and DC coupling!
Best regards!
Message 10 of 10
(7,702 Views)
