problem with DAQ assistant on LABVIEW.
I installed the evaluation DVD today and when I placed my DAQ assistant in the code, I had a screen telling me that my license was not okay.
But my DAQ license is original .....
Just normal situation ?
grts
Message 11 of 14
(2,272 Views)
does that mean I should remove DAQ 9.0.2 and install 9.2.3?
Message 12 of 14
(2,262 Views)
Only if you want to use daq with 2010
Message 13 of 14
(2,260 Views)
Accepted by KDGREAT.
Here is a KnowledgeBase that shows the compatibility of LabVIEW with DAQmx. NI-DAQ and LabVIEW Version Compatibility (for Windows)
Since you have LabVIEW 2010, you will need at least 9.1.5, as Dennis Knutson mentioned, but I would suggest using DAQmx 9.2.3.
Applications Engineer
Message 14 of 14
(2,246 Views)
