problem with data saving into text file
The problem I am facing wihile saving the data into text file is that everytime when I am slecting the path from front panel, the data which is being saved is appended with the previous data, i.e. not only in the new text file, the new set of data is saved but also, if there is any previuos run for the program, the corresponding data is also present in that text file.
However, when I change the same 'control'(file path) to 'constant' in the block diagram, and add the file path, there is no such problem. Basically, changing the "File path" from constant in the block diagram to control (so that it is displayed in the front panel) is causing the problem.
Please help!
(3,129 Views)
Accepted by topic author ainat
Your shift register on the For loop is not initialized. It will retain the value of the string from the last time it executed. Initialize that and it should solve your problem.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,116 Views)
Thank u very much. Its working fine now.
(3,106 Views)
