save image using write file2
I am acquiring real time images using laptop web camera.
I want to save them and read them to use in another application.
I connected the vision acquisition express to imaq write file 2.
I used imaq read file to read the written image files.
When I tried I encountered the following problem."Error -1074395989 occurred at IMAQ ReadFile
Possible reason(s):
IMAQ Vision: Unable to read data"
Thank you for your help.
(3,044 Views)
Can you show the VI you are using to save and to load the image file?
Here's a little example for how to read an image from file and display it :
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,037 Views)
Thank you for your response.
Please check the vi attached.
I want the main vi modified.vi to be fixed.
(3,029 Views)
