problem with image rotation
For the attached code for by giving the inputs to a single cordinate by keeping other cordinates ==0 . everythin is ok.
But if ikeep some x = 10 and if i am varing y image is getting to starting position. what might be the problem
Message 1 of 8
(4,017 Views)
Accepted by topic author Nagaa
First, you probably don't want to use a timeout case but instead change this to a "Value Change" event that checks X, Y and Y. This will be significantly more efficient (right now, even if nothing is changed, you are recalculating the image every 2 ms...). See attached modification.
Next, what do you want to do? As you probably know, rotations in 3D are not commutative (e.g. a rotation around X followed by a rotation around Y is not the same as the two operations accomplished in the opposite order). Your code currently specify the rotation axis (the cluster of X, Y, Z coordinates) by passing ANGLES. That's probably not what you want to do. This cluster specifies the axis VECTOR. The other parameter, which is the angle, needs to be controlled by a separate parameter. Therefore, if you want to rotate either around the X, Y or Z axis by a specific angle, you probably want to do what I did on the attached modified version 2.
Message 2 of 8
(4,005 Views)
Thank u sir
Message 3 of 8
(3,992 Views)
In my below code can u help me why the below object is rotating slowly without any delay please
Message 4 of 8
(3,977 Views)
take x = 20 y = 30 = 20 then observe the code
Message 5 of 8
(3,959 Views)
I don't understand what you are trying to do and what the question is. If something is rotating slowly, it exhibit some kind of delay, so it cannot be rotating "without any delay". Incidentally, are you planning to expand your diagram to several more screen widths?
Message 6 of 8
(3,952 Views)
Application : to rotate a ball according to the xyz inputs
what i mean is  in that vi. under event structure ( ok button value change ) ,  i kept one while loop,  that loop is executing slowly .
i want to know why that loop is executing too slowly
Message 7 of 8
(3,938 Views)
The reason is that the action in the "Scene Window" case (Render to Image) takes a significant amount of time. On my not-so-new dualcore desktop, it takes about 230 ms per iteration...
If you replace your Picture indicator by a 3D Picture and directly connect the wire that you are currently connecting to your Scene property to it, this is pretty much instantaneous:
Message 8 of 8
(3,920 Views)
