problem with my code
my code is giving me trouble. Ok! I want to move the needles guage to diffent positions. right now, I am concetrating on moving the  red needle but as it move the other needle should also move but that one is not troubling me, i have done it. The problem is I want the loop to terminate when the red needle reach a value of 270, but it does not. I have posted the main VI and the subVI I have used to test the code.
Please help!!
(2,852 Views)
Hi netee,
your program do exactly what you want, the only problem is if the value you enter is exactly 270, but this depends on: see this thread
Mike
Message Edited by MikeS81 on 04-04-2008 10:42 AM
(2,849 Views)
Using exact numbers with floating point is troublesome
Message Edited by JeffOverton on 04-04-2008 08:09 AM
(2,824 Views)
