Can a 1D array of boolean be entered into a case structure?
Message 1 of 14
(5,307 Views)
yes
Richard
Message 2 of 14
(5,305 Views)
just not as a case selector
Message 3 of 14
(5,298 Views)
How is that achieved?  I have a waveform that is being coverted into a 1D boolean.
Message 4 of 14
(5,297 Views)
take your 1D array and wire it to the edge of the case structure.  this will let you use the data in the case structure, but it will not let you select a case based off of the entire array.
Message 5 of 14
(5,295 Views)
Oh I need it to be a case selector.  Is there a way to continuously have the waveform enterend into the case selector?
Message 6 of 14
(5,294 Views)
Put a for loop around the case structure Smiley Very Happy
But you should start with telling us where the data come from and what you want to do with it...
Message 7 of 14
(5,289 Views)
Using an array as a case selector makes me think you want to do true or false conversion, in which case you can wire a boolean array to "bool to 0,1" and get a binary array, which you can then do math on easily.
Message 8 of 14
(5,284 Views)
I have a DAQ card hooked up to an optical tachometer.  With every rotation of the drum, the voltage jumps to 3.2V.
I am using the case selector to count the number of times the voltage is over 3 to count the number of pulses.
This will be relayed into a equation to calculate RPM, but I want this to be continuous.
Message 9 of 14
(5,282 Views)
here's two options
edit - to get to the boolean array, you can just wire your waveform to a Greater Than primitive.
Message Edited by JeffOverton on 04-03-2008 05:05 PM
Message 10 of 14
(5,271 Views)
