problem with runtime enginge for labview 8 and windows XP
I'm trying to run an application (executble), programmed and compiles on labview 8, and to run it on win XP
I've intalled the drivers for the NI USB-6008
and the runtime for win XP labview 8
After all of that I get the following errors - please see attached
(3,015 Views)
Are you sure you actually installed the DAQmx drivers on this PC?
Are you sure the version of drivers you installed works with the LV8 run-time engine?
(3,014 Views)
How can I make sure that I'm using the correct Daqmax drivers for labview 8?
(3,011 Views)
Look in the software section of Measurement and Automation Explorer and see what version it says you have installed.
(3,007 Views)
I'm getting this error when trying to run the app(executable) on a computer with out labview or Measurement and Automation.
So what should I do?
(2,996 Views)
I would suggest you include MAX as well as exporting the hardware config. If you configured any tasks or scales, you must include the hardware config.
You said you installed the driver for the 6008. Was this part of building the installer? If so, then you probably installed whatever version is on your pc. Otherwise, if you downloaded DAQmx, I would hope that you remembered what exactly you downloaded but you can always open regedit and go to HKEY_LOCAL_MACHINE>Software>National Instruments>DAQmx.
(2,988 Views)
Gil,
Here are several links that should help point you in the right direction.
Distributing Applications with the LabVIEW Application Builder
http://www.ni.com/white-paper/3303/en
NI-DAQ and LabVIEW Version Compatibility (for Windows)
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248?OpenDocument
Windows Version Compatibility with LabVIEW
http://digital.ni.com/public.nsf/allkb/B972242574D4BB99862575A7007520CB?OpenDocument
National Instruments Drivers
http://www.ni.com/downloads/drivers/
Josh B
Applications Engineer
(2,963 Views)
