problem with runtime enginge for labview 8 and windows XP
I'm trying to run an application (executble), programmed and compiles on labview 8, and to run it on win XP
I've intalled the drivers for the NI USB-6008
and the runtime for win XP labview 8
After all of that I get the following errors - please see attached
(3,556 Views)
Are you sure you actually installed the DAQmx drivers on this PC?
Are you sure the version of drivers you installed works with the LV8 run-time engine?
(3,555 Views)
How can I make sure that I'm using the correct Daqmax drivers for labview 8?
(3,552 Views)
Look in the software section of Measurement and Automation Explorer and see what version it says you have installed.
(3,548 Views)
I'm getting this error when trying to run the app(executable) on a computer with out labview or Measurement and Automation.
So what should I do?
(3,537 Views)
I would suggest you include MAX as well as exporting the hardware config. If you configured any tasks or scales, you must include the hardware config.
You said you installed the driver for the 6008. Was this part of building the installer? If so, then you probably installed whatever version is on your pc. Otherwise, if you downloaded DAQmx, I would hope that you remembered what exactly you downloaded but you can always open regedit and go to HKEY_LOCAL_MACHINE>Software>National Instruments>DAQmx.
(3,529 Views)
Gil,
Here are several links that should help point you in the right direction.
Distributing Applications with the LabVIEW Application Builder
https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
NI-DAQ and LabVIEW Version Compatibility (for Windows)
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Windows Version Compatibility with LabVIEW
https://www.ni.com/en/support/documentation/compatibility/17/labview-and-microsoft-windows-compatibi...
National Instruments Drivers
https://www.ni.com/en/search.html?pg=1&ps=10&sb=%2Brelevancy&sn=catnav:sup.dwl.ndr
Josh B
(3,504 Views)
