problem with web publising tool
Hallo,
I got a question about the web publishing tool in labview 2010.
I made a VI and published it with this tool and it works fine, but the problem is that you can run and stop the VI from the website.  Is it possible that the user of this website only can control the front panel and not stop the program?
Jochem
(3,383 Views)
did you tried to change properties of your vi ?
File => Vi Properties =>Window Appearance => Customize => Uncheck Show Run button and show Abort Button.
This should solve your problem.
V-F
(3,375 Views)
Thanks for the reaction,
But if I uncheck "show run button", i can not run the program.  Even not with CTR + R.
The program i wrote must be running on a computer and must be controlled over a website, but may not can turn of from the website.
Are there any other solutions.
Jochem
(3,368 Views)
did you tried to launch your vi with CTR + right arrow ?
V-F
(3,364 Views)
Hey,
Right arrow works!
thanks a lot
Jochem
(3,360 Views)
thanks to mark the thread solved.
V-F
(3,356 Views)
