Programmatically adding items to LVOOP class private data cluster possible?
I would like to programmatically (i.e., by VI scripting) add a strictly typed subcluster to the private data cluster of a LVOOP class.
In the VI server interface, I haven't found a property node giving access to the private data cluster of a LVOOP class. Is there any way to perform the operation mentioned above?
Thanks in advance for any help!!
(3,358 Views)
In newer versions the LVClassLibrary class has a Class Data Control property which returns a reference to the private control VI, which you can then parse through like any regular VI. Additionally, if the class is in memory, you should be able to open a VI reference to MyClass.lvclass:MyClass.ctl to accomplish the same thing.
That said, I have no idea what happens if you try to edit that control. I assume it should work, but that's just a guess.
___________________
Try to take over the world!
(3,346 Views)
