problems about the PSD vi
I have two problems.
In labviews there are 2 vi models "spectral measurement" and "FFT power spectral density" which both can calculate PSD of noise. Is there any difference between them or they are the same about PSD values.
I can apply them to measure PSD of noise whose output unit is dB directly.How can obtain the PSD whose unit is v/sqrt(Hz).
(3,680 Views)
I would use "FFT Power Spectral Density." The "Spectral Measurements" VI has a whole lot more stuff, most of which you might not need.
I've attached an example VI that creates a noise waveform with a sample rate of 1 MS/s and a noise density of 1 nV/rt(Hz). It calls the spectral density VI and displays the result. Notice that I had to take the square root of the data, because we want voltage spectral density but the VI returns power spectral density.
Hope this helps,
Ed
(3,651 Views)
Thank you very much!
(3,641 Views)
Dear Sir,
I want to the same PSD function in LabVIEW 7.1(Base Package). What kind of the functions can I use? Thank you!
(3,601 Views)
Hi Ancle,
it´s also available in LabView 7.1, but i´m not sure if it exists in the Base Package.
Mike
(3,597 Views)
