problems converting string to floating point
Dear reader,
System:
Windows 2000 with Labview 8.0 updated to 8.0.1
I have problems converting a string to a floating point number. The string I want to convert is "+000.41". If I feed this string into a Fract/Exp String to Number object the result is 0. I found this a little bit strange so I check it at a differnt computer and there the result was 0.41. The only differentses between the systems was the version 8.0 and 8.0.1 and the opperating system windows 2000 and Xp. So I run an update to update the version to 8.0.1, but that didn't work.
Now I'm stuck and don't know where to look for a solution. So can you help me?
With best regards,
K. Zwetsloot
(4,427 Views)
Just an idea... Have you checked the definition of the decimal point in the Windows settings ?
(4,422 Views)
Accepted by KHZ
One of yoiur computers is set to german (or similar), with a comma as decimal seperator. Go back to the "Fract/Exp String to Number" and wire a FALSE to the top terminal.
From the help:
"use system decimal point defines the decimal separator. If TRUE (default), the decimal separator uses the localized decimal separator. If FALSE, the decimal separator is a period"
Message Edited by altenbach on 07-25-2006 08:11 AM
(4,416 Views)
Thanks everyone. That was the problem, so it is fixed now!
(4,372 Views)
If I read his name right, I think the language is dutch!
Ton
My LabVIEW Ideas
(4,370 Views)
