problems querying from microsoft access
The only time you'll get into trouble is if you have two different cal factors for the same frequency.
As long as you are sure the frequencies are unique, then that SQL query will always work.
Message 11 of 12
(973 Views)
Ok, I think the problem is solved then.  We always use one frequency to one cal factor.
Message 12 of 12
(970 Views)
