problems with shift register
Hi yameada,
I checked with the idea you gave, but can you tell me why have you used  array size and index arrey in between the two case structures?
I have decided to redo my main code that is collecting the data from the LIN network and then change this code for checking the output. I am having lots of problem with the main code for LIN network. Will work on that now. Have to fix that immediately.
Thank you.
Message 31 of 33
(1,005 Views)
Since we're looking at a small array of Data i use Build Array to save the 4 last data arrays, resulting in a 2D array.
The Index Array and Array size is to check the number of rows i currently have (the number of columns is of no interest). Since i now have a 2D array the Array size will give a 2 slot array as result. (unless i wired it wrong so you get the number of columns)
If i have >4 rows i want to remove the 1st row (thus array subset).
/Y
Message Edited by Yamaeda on 04-09-2010 08:35 AM
Qestit Systems
Certified-LabVIEW-Developer
Message 32 of 33
(1,004 Views)
Oh ok, now i get it. I will try to fix the main code soon and then try using this concept and check the output. Thank you for all the help.
I will let you know how it goes.
Thank you.
Message 33 of 33
(994 Views)
