This widget could not be displayed.
processing the array elements
      I have a very simple question but trying to figure it out for a long time.I have an array of  'n' elements.which represents digital data.What my aim is representing the first 8 elements as a byte in the new array.Anyone please suggest some simple methods.For example:-
Message 1 of 42
(5,682 Views)
Maybe:
Christian
Message 2 of 42
(5,674 Views)
Hi christian,
                  Thanks for immediate reply.I need a hex string as output.I just try and get you soon.
Message 3 of 42
(5,670 Views)
Use
On the front panel with your mouse over the indicator...
Right Click  >>  Display Format  >>  Hexadecimal
Never say "Oops." Always say "Ah, interesting!"
Message 4 of 42
(5,666 Views)
Hi, If the input array is also a hexadecimal then how can we adopt this method?
Message 5 of 42
(5,658 Views)
If the values in the initial array are not boolean (at least from the meaning), you will introduce data reduction. This will most probable result in plainly wrong values.
Norbert
Norbert
Expert: Geometry
Message 6 of 42
(5,654 Views)
Thanks for all the suggestions.I figured it out.
Message 7 of 42
(5,647 Views)
      when I tried something different like the attachment.It seems to be not working.What is the problem with it?
Message 8 of 42
(5,640 Views)
        I want to see the next 8 array elements to be converted and has to display in the next index of the second array.But it is showing nothing.
Message 9 of 42
(5,635 Views)
We can't answer that question because you haven't told us in what way it is not working.
What are you expecting and what are you actually getting?
Please attach your VI with actual data saved in the controls as default so we can see what kind of data you are trying to work on.
EDIT:  You posted more information while I was creating this message.
You need to typecast your U32 number into a U8 array.
Message 10 of 42
(5,630 Views)
