producer consumer "clean up diagram" puts consumer on top of producer
I do File > New... > VI > From Template > Frameworks > Design Patterns > Producer/Consumer Design Pattern (Events)
Then without doing anything to the block diagram or front panel, I click on the "clean up diagram" which does the auto block diagram cleanup.  Bam! Consumer loop is put on top of Producer.
I tried a bunch of combinations of the Block Diagram options settings (wire spacing, move controls left, etc.) , but the "clean up diagram" always wants to put consumer loop on top of the producer loop.  How can I get labview to maintain the original loop positions?
(3,088 Views)
If you select one part of a diagram before doing the cleanup, it will only cleanup the selected code. Why does it bother you? Functionally it makes no difference.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,083 Views)
There is a reason a lot of use do not like to use the Block Diagram Cleanup.  It generally works for simple VIs.  But I would not use it on my top level architecture.
(3,068 Views)
