straight line
Hi how to make a straight line without using decorations? does a draw line tool in picture function can be a staright line?
Thank you
(4,228 Views)
You want a line on your front panel? The pictures functions will need a picture control to work, is it what you have?
(4,223 Views)
Yes on my front panel.
I try to draw the picture function using draw line but it cant be a straight line. How ya?
Thank you.
(4,217 Views)
Why can't you use a decoration?
(4,209 Views)
I aready draw a circle and display in new picture.I have about 10 pictures to display. if I used the decorations, the straight line is overlap for all pictures. so I try to use straight line using picture function but I cant get it. how  to make a straight line using picture function and how to make one picture display at one time?
(4,205 Views)
Use a combination of Move Pen.vi to move your pen to a start point.  And then Draw Line.vi to draw the line to another endpoint.
(4,202 Views)
