05-25-2010 01:43 PM
Shalom,
excuse me for my ignorance... but, is it possible to program my cRio without FPGA or RT (only LabView 8.)
I want to use a cRio as a datalogger for analog measurements (1-10ms) and don't have those modules...
Thanks for the information
05-26-2010 02:27 AM
Hey G. Eshel,
I don't think that is possible. If your cRIO Controller is 9002 or 9004 you need at least LV FPGA and RT Module. Otherwise, RT Module (only for version 8.6 and above) is sufficient.
Cheers,
w15nu
05-26-2010
12:25 PM
- last edited on
03-14-2025
01:07 PM
by
Content Cleaner
G. Eshel,
w15nu is correct, it is not possible to program cRIOs without at minimum the LabVIEW Real-Time Module, however, the ability to only use the Real-Time Module (without the LabVIEW FPGA Module) requires the use of programming the CompactRIO in Scan Mode which is only available with VxWorks based CompactRIOs (901x,902x,907x) using LabVIEW 8.6 or later. For Programming the FPGA of the CompactRIO, programming 900x CompactRIOs , or programming any CompactRIO before LabVIEW 8.6, you then also need the NI FPGA Module.
05-26-2010 06:11 PM
05-26-2010 11:58 PM
Thank you all for the information, I'll see how can I proceed with it.
Gonen
