program time not stable
Yes I tried it with your last example. No improvement and no errors.
I thought about he same, that the computer clock is not stable.
Thanks a lot for your help. I talked to my boss and he said I should by the more expensive power supply with a build in pulse module, but let me know if you have another idea for the problem.
Message 11 of 17
(1,787 Views)
One thing...do you guess that the CPU speed is not accurate enough or the speed how Windows handle the program is not accurate?
Message 12 of 17
(1,779 Views)
It would be more Windows related..
However.... if you wanted to try a more exotic trick, there is something you could try..
Are you using a multi-core PC and Labview 8.5?
RayR
Message 13 of 17
(1,762 Views)
I have a Intel Core 2 Duo processor and LabVIEW 8.5.1
Message 14 of 17
(1,756 Views)
The other technique I'm thinking of consists of having two loops (two execution threads) where one thread is concerned with turning OFF the power supply and the other one to turn it ON.  Each execution thread would be tied to a CPU core and a notifier would tell the other thread when it can execute.  Each loop would execute one iteration and wait until the other loop sends a notification to proceed.  The delay would be between sending the command to the instrument and before sending the notification.
I'll look for the discussion on this topic.
RayR
Message 15 of 17
(1,747 Views)
Hey,
It was a good idea and try with the duel core processor, but the problem is, that the computer on which the program should run has no duel core processor.
Is there any other idea to provent this problem?
thanks
Message 16 of 17
(1,714 Views)
Timing precision with Windows is not easy...
I'll have to think about that..
Message 17 of 17
(1,696 Views)
