programatically block window close
Is there a way to disable a user's ability to exit the window while the program is running.  For safety, I want to force the user to terminate all of the outputs before quitting the program.
Message 1 of 8
(4,336 Views)
Accepted by grabeer
Hello grabeer
Catch "Panel close?" event and discard it if the application is not ready to stop.
Message 2 of 8
(4,333 Views)
You may also want to include Application Instance Close? too.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(4,327 Views)
You can also go to File -> VI Properties -> Customize -> uncheck Window has Title bar.
Ben64
Message 4 of 8
(4,322 Views)
Ben64
Can this be set during run-time?  It sounds like the OP wants to enable closing of the close window once the shutdown process has happened.
Message 5 of 8
(4,316 Views)
You're right, it cannot be set during run-time. Usually I do as specify in a previous post: filter the panel close event, make sure everything stop properly and then exit the application. If you don't show the title bar you can provide a stop button that do the same thing (I usually do this for a vi loaded in a subpanel).
Ben64
Message 6 of 8
(4,311 Views)
Ben64
I generally do it the same way. Only I add the Aplication Instance Close? and a user exit event. I have the panel close and application close fire the exit event which has all the cleanup code. That way I have one means of actually exiting the application and I can be assured that the cleanup code has been executed.
Mark Yedinak
LabVIEW Champion
Message 7 of 8
(4,302 Views)
worked perfectly...thanks!
Message 8 of 8
(4,297 Views)
