programatically controlling vi properties
hey can anyone tell me how to programatically control the properties of a vi ?
Message 1 of 14
(5,050 Views)
Hi dhiraj034...,
here is an example with some properties.
Hope this helps.
Mike
Message 2 of 14
(5,048 Views)
Hi dhirah,
general answer: using vi server capabilitiesSmiley Wink
Do you have any more information?  Any more detailed questions? What property are you interested in?
Message 3 of 14
(5,047 Views)
hey
i wanted to modify the properties of the combo box icon on the front panel programatically.
Message 4 of 14
(5,008 Views)
If you see the example VI Server - Changing Another VI's Properties.vi in the4 Examples Finder in LabVIEW, you ll get an idea on the whole about changing the properties of 'anything' in LabVIEW.
To change the properties of a Combo control, you can use the position, bounds & size properties of it. Smiley Happy
I think these are the properties you are looking for.
- Partha ( CLD until Oct 2027 🙂 )
Message 5 of 14
(5,002 Views)
dear frnd
i am trying to control the option which are available in the properties.just like the drop down menu,but the options should be taken frm a database field .did u get what i am searching for?
Abhimaniu
Message 6 of 14
(4,930 Views)
Right click on the combo box and select 'Create>Property' and then browse through all of the properties that are available. Some are read only but the ones that aren't could be set by reading a file/database and properly parsing the contents. The mention of the 'drop down menu' implies to me that you just want to populate the comb box. That requires passing an array to either the Strings[ ] or Strings and Values[ ] property. If that's not what you want, provide some details.
Message 7 of 14
(4,925 Views)
yes thanks
Message 8 of 14
(4,861 Views)
HI,
I need to make the property 'display vi front panel' on/off according to a Boolean input.
Should I still use the VI-server technique (it seems complicated...) or, may be there's a shorter way?
Rafi
Message 9 of 14
(4,609 Views)
Hi Rafi2003,
you can use the property "Front Panel -> Open". There is also a method to hide the front panel.
Mike
Message Edited by MikeS81 on 03-31-2010 06:59 AM
Message 10 of 14
(4,574 Views)
